02 Durango tire size question.
Old Dec 4, 2011 | 02:18 PM
95SHO's Avatar
95SHO
Default 02 Durango tire size question.
I have a 2002 Durango and I need to find a set of tires for it. What is the biggest tire I can put on there with the stock ride height without any rubbing.
I searched but I only found a sticky about Ram tire sizes.
Old Dec 4, 2011 | 02:28 PM
Radar696's Avatar
Radar696
Well if you have 15" rims you can use 31x10.5x15 tires with no trouble.
You can use 32x11.5x15 but you need to crank the front torsion bars and put in some helper springs out back.
These will rub in the front at full lock.
I'm not sure what size to use right offhand if you have the 16" rims.
I'm betting that someone will show up mighty quick and let you know.
You can also do a search because I'm pretty sure someone had asked a similar question just a week or two back.
Old Dec 4, 2011 | 04:48 PM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
31 inches is the maximum diameter that you can fit, i believe that is 265/70/16 or 31x10.5xZ (where z is your rim size, 15 or 16 inches)
Old Dec 4, 2011 | 09:55 PM
95SHO's Avatar
95SHO
I have 16s.
Old Dec 5, 2011 | 04:08 PM
Instant Classic//'s Avatar
Instant Classic//
265/70/r16. There you go bud. I have a set on mine, and they fill out well.
