power window
Old Dec 9, 2011 | 02:34 PM
kmalo86's Avatar
kmalo86
Default power window
hey guys my window switches wont work on the individual windows but master still works any ideas on what this could be and how to fix the problem?/
Old Dec 9, 2011 | 02:51 PM
that_guy's Avatar
that_guy
The master switch probably needs replaced
Old Dec 9, 2011 | 03:17 PM
whollysheet's Avatar
whollysheet
if you need a master switch depending on the year i have quite a few post a pic id only charge you shipping i also have passenger fronts
Old Dec 9, 2011 | 04:55 PM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
is the master switch 'locked'? if its unlocked then the lock switch is busted, easiest option is to replace the master switch.
Old Dec 9, 2011 | 10:19 PM
kmalo86's Avatar
kmalo86
its an 01 my lock button on the master panel doesnt seem to be working either which probably is the cause. none of the individual switches function only from the drivers master panel can the windows go up or down
Old Dec 9, 2011 | 10:31 PM
that_guy's Avatar
that_guy
the lock button only disables the switches on the other doors, the master switches will work whether its locked or unlocked
Old Dec 9, 2011 | 11:21 PM
shrpshtr325
THE ULTI-MOD
it disables the WINDOW switches on the other doors
Old Dec 9, 2011 | 11:49 PM
that_guy's Avatar
that_guy
well I figured he'd know that since he didn't say anything about the lock switches acting up
Old Dec 10, 2011 | 01:04 AM
kmalo86's Avatar
kmalo86
im thinking its the locking switch thats busted if i replace the master will that take care of the problem?
Old Dec 10, 2011 | 01:26 AM
hydrashocker's Avatar
hydrashocker
The master door drivers switch controller has diodes in it that will stop the other independent switches from working. Replace the main drivers side switch.
