Noise in front end when I accelerate
Old Jan 7, 2012 | 08:32 AM
toddinav's Avatar
toddinav
Default Noise in front end when I accelerate
2000 2wd 127,000. like a light clank noise. A week ago I replaced the front brake rotors and pads with new ones. Took off the hub nut on the left side but not on the right. Now I hear a faint clank noise when I push on the gas from a complete stop. I live on a semi bumpy dirt road and also hear it just going slow(it's not as loud.) Brakes work great and the hub nut and lug nuts are torqued properly..Any ideas? thank you
Old Jan 7, 2012 | 10:00 PM
ColoradoBronze's Avatar
ColoradoBronze
I am not sure if the 2WD has a front sway bar, but it might be a broken sway bar link if it does have one. Easy to replace if it is broken though.
Old Jan 11, 2012 | 02:28 AM
moparmuscle's Avatar
moparmuscle
Cool
check your controll arm bushings the passenger side uppers tend to prematurely fail do to the motor is offset to the pass side and the heat from the manifolds. open your hood and look down to where the control arm is bolted to the frame and make sure u see rubber between the arm and the nut/washer on both ends. mine started doing it everytime i went from reverse to drive then when i accelerate. looked at them and there was no bushing left
