heater help
Old Feb 7, 2012 | 05:32 PM
spork40's Avatar
spork40
Default heater help
the heater works great upfront, but what would cause the rear vents to blow cold? i have the heat on high upfront and the rear controls set on high but they blow cold, how do i fix that?
Old Feb 7, 2012 | 06:43 PM
mikeismadness's Avatar
mikeismadness
Are u positive you have rear heat? Mine only has AC in the rear
Old Feb 7, 2012 | 09:23 PM
spork40's Avatar
spork40
why wouldn't the rear have heat?
Old Feb 9, 2012 | 03:03 PM
Compactc9's Avatar
Compactc9
98-00 had rear A/C only, 01-03 had rear heat and a/c. Someone else will have to help you more, but th first thing to do is make sure both hoses going to the rear heater core get hot, otherwise you may have a blend door problem too.
