power window, motor or ?
Old Feb 28, 2012 | 12:38 AM
otgarzā's Avatar
otgarzā
Originally Posted by KimberlyAnn7911
Thanks everyone, that was a lot of useful knowledge that you have lended. I will see what I can find. And not to sound like an idiot but, the "master" switch is the one that controls everything on the drivers door right?
Correct. First you should check both switches and make sure theyre plugged in and then afterwards try swapping out switches from a junkyard. And if that doesnt fix your problem you can get a motor for $60 on ebay.
