02 with4.7 rough idle and miss.
i just replaced the heads on a 02 durango, Heads are go the timing is right on. At 600 rpms the engine misses and will stall. Go down the road runs fine or any engine speed above 1000 rpms. replaced the icv and ohmed out the TPS and the Map. and get. put it on the scanner and i get the codes for coil fault on all 8. i think its P035? and it for A,B,C,D,E,F,G,H. I'm starting to think now that it may be the PCM. can any one help.
https://dodgeforum.com/forum/dodge-d...s-section.html
you wont get any help posting here, ill move the thread for you this time, but next time consider reading the rules BEFORE posting, thanks.
No 035 but what about
P0335 Crank Pos Sens Circ?
Also make sure you are running the cheap Champion Copper plugs in that motor, it has to be copper because of the aluminum heads, tells you right in the factory manual. Gap em at the .040 and call it a day.
