had a rear line bust,and abs and brake light came on,replaced line from abs pump all the way back and replaced both rear wheel cyl, but have no fluid going to abs pump and lights still on. front brakes work fine. but not getting fluid thru the "proportioning" or "control" valve. pls help
that may be true also,but not getting fluid thru valve before the abs pump,master cyl working. just not traveling thru the control valve, if i could get fluid thru that to abs pump i could then bleed the pump.
