Pinging under acceleration
Old Mar 13, 2012 | 06:27 PM
lvphotos's Avatar
lvphotos
Are you at least running 87? I run into 85 once in awhile and none of my toys run on it. High altitude or not. When towing I run mid grade or premium. In summer in Las Vegas is when the pinging starts due to heat but man my trucks have been running ruff this winter. Down on power and hard to start. Ran Shell, BP, and Sinclare. BP being the best.
Old Mar 13, 2012 | 09:30 PM
mikeismadness's Avatar
mikeismadness
Originally Posted by shrpshtr325
you are wrong, the plugs are a 30k mile part, if you want to change them more frequently thats fine, but dont be telling others to waste their money, unless there is a problem with the plugs 30k miles is the change interval
I'm just goin off what hydra said with that. I've always changed mine around 15,000-20,000 and they look a little rough. It depends on more how u drive and what kibd of fuel usage. I live where we can get in the - temps and use ****ty winter gas.
Anyway, in a sense I believe there really isnt a right or wrong answer personally. $20 bucks a year for plugs i wouldn't say is a waste of money. But ultimately its the owners decision
Old Mar 14, 2012 | 11:59 AM
monster406s10's Avatar
monster406s10
Yes I don't think we have 85 octane up here unless I just haven't seen it before. I ran 89 octane in it yesterday and it seemed to quiet down the pinging, I can still hear it if I really sink my foot into it so 91 would probably cure it.
Old Mar 14, 2012 | 02:22 PM
adukart's Avatar
adukart
Thats just a bandaid solution. Still there is an underlying issue here.......
Old Mar 14, 2012 | 03:14 PM
Radar696's Avatar
Radar696
Thank you for the replies. I did a tune up on it over the summer, new cap, plug wires and plugs. I could not get the friggin rotor off but anyway I was going to out some 89 octane in it today to see if it helps any. Just seems weird, you would think sense it has EFI the computer would pick up on the pinging and adjust the timing so it doesn't ping.
I've been having a simular problem with mine and I'm looking to replace distributor cap, rotor and plugs for sure.
Possibly the wires, that remains to be seen.
It's been probably 40,000 miles since my last tune-up.
For you I would say double check the inside of that distributor cap.
If I read your message correctly you weren't able to change the rotor cap.
That could be your problem but it's also possible that your distributor cap is bad and allowing moisture in.
I'm sure you realize that with these things age has nothing to do with life span!
Radar
Old Mar 14, 2012 | 11:03 PM
alwaysclean19's Avatar
alwaysclean19
I have a 2000 R/T 5.9L and I have always found that it would ping if i ran lower octane. If it's pinging the higher octane will defiantly help a lot. I run 93 octane in my truck and never have any problems. Also try adding some STP in a tank of gas and clean out your fuel system it might help, I do it every couple of tanks and have no problems with pinging anymore, winter or otherwise. Truck has been on Long Island its whole life though so the weather is defiantly milder here. I hope you can fix it because I know how annoying it can be.
Old Mar 14, 2012 | 11:24 PM
Radar696's Avatar
Radar696
I forgot to add that I use Lucas fuel treatment on a regular basis.
I found that i can get at Farm & Fleet for about $24.00 a gallon.
I have one of the small single treatment bottles and one of the quart size bottles in a box in the back of the truck at all times.
I use the gallon to fill the quart bottle, this bottle has that small tip on it.
I use it to fill the 5 oz. bottle.
I put in a bottle full at least once every couple of weeks.
At $24.00 per a gallon it's fairly inexpensive to use on a regular basis.
Old Mar 14, 2012 | 11:47 PM
hydrashocker's Avatar
hydrashocker
+1 plugs should be changed every 15,000!
Oh yea, just blame it on hydra.....LOL
And "Lucas", well your just wasting your money......IMHO.
Old Mar 14, 2012 | 11:51 PM
mikeismadness
Haha, sure why not?! The Lucas stuff made my p0420 code go away, and now its back. I cant remember the name of the other stuff I used, but I'd say it helped my fuel system
Old Mar 14, 2012 | 11:56 PM
Radar696's Avatar
Radar696
Well I can not honestly say that it's made any noticable difference in my truck but I did work with a guy for a while that started using it on his truck and saw a noticable improvement!
I know what his truck ran like before and after and you could recognize the change.
His truck was pretty bad when he first started working there!
That is my only testimonial.
