Need help!
Alright here goes I have a 2000 Dodge Durango 5.9 L. has had some whining while driving lately. higher in pitch and volume the faster you go. recently it switched to a slightly grinding noise and now I have a clunking noise coming from the front end. I don't dare drive it and it is our only vehicle. If someone has had this issue before and knows what it is, That would be fantastic. I am currently thinking major issue such as either front differential or the transfer case. I hope I am wrong but any help would be great. Thanx all.
def a wheel bearing and super easy to replace. i myself have a bad fan clutch that needs replacing
it could be other things too but unless you check part by part where the sound is coming from you wont know.
i had a whine noise coming from the front thought it was the power steering pump ended up being the trans and the clutch on the fan. take it to a garage if your unsure of wherre it is coming from.
