Water in my oil :(
I would say HG. Unless you somehow got coolant down the oil pan when you replaced the waterpump or something. Never changed a waterpump on a dodge, but fords usualy have a gap filled by the waterpump and timing chain that coolant leaks into.
Maybe?? It did not have water in the oil before we changed the water pump....I was checking. However the oil pressure was higher than usual before the water pump and is still at 3/4 just sitting still...??
is this reading with the engine hot? bc when its cold the oil pressure will read higher, also check right after turning the engine off if the oil pressure gauge drops, you could have a sensor which is just reading high.
Yeah it is when it's warm...doesn't move much at all when you accelerate either....I keep my eye on it usually. I went ahead and bought the head gasket set for it and we're about to get to know this engine a lot better. I'm not sure what else to do?? It's the only car I have and I need one yesturday
I am pleasly surprised that it's been pretty easy to work on so far. This is the only problems I have ever had and I've owned it for about 5 years!
Yeah a head gasket is in order!! We took off the radiator and got it tested trough a local shop! It was trashed! So we got a new radiator to go with this head gasket set and we started taking it apart. Not sure if you can post pics but I will try! All I can say is WOW!
http://www.facebook.com/#!/photo.php...type=1&theater
