Speedmoter don't work
Old May 9, 2012 | 02:04 PM
Russ50's Avatar
Russ50
Default Speedmoter don't work
I was told from Advance Auto Parts that my speedmoter don't work cause the speed sensor is bad, They put the test thing they have on it,, I replace the sensor with a new one an my speedmoter still don't work,, Can anybody tell me if there is a fuse or something else that I can check to get the speedmoter to work ??? An yes my check engine light is on an thats why I took it to Advance to let them do the test for me,,
Old May 9, 2012 | 06:48 PM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
so what code is coming up when you check it? i bet having that information would be helpful
Old May 10, 2012 | 12:14 AM
Russ50's Avatar
Russ50
They didn't tell me the code,, Just told me the sensor in trans was bad but I found out today that there is also another sensor on the rearend so I went ahead an ordered it today an will get it next day an will see what happens then,,
Old May 10, 2012 | 08:44 AM
Old_School's Avatar
Old_School
And that there is why i don't deal with advance or any chain store for that matter...
Chances are they don't know the code either (or what it means atleast) MOST of the people that work at those type of stores watched an afternoon of the Powerblock on spike, washed up, and now claim to be Master techs for all makes and models. Hell, the manager at our local Advance just hired his 16 y/o son!
While i will agree watching Courtney Hansen, AJ, or Jessi Combs work on a car is pretty hot that is NOT formal education to make you a certified auto tech.
now back to the issue.... There is a speed sensor on the rear axle and there is a trans. output sensor on the back of the trans. IIRC they both have a part in the SPEEDOMETER. with that being said, if indeed it was the trans. output sensor you replaced the first time, then replacing the speed sensor on the rear axle should fix it... if not then i would look into the speedometer itself as in the stepper motor that controls the needle may be shot. that be the case let me know, i may have an extra laying around here that may make its way in the mail and suddenly become yours.
Old May 10, 2012 | 10:55 PM
Russ50's Avatar
Russ50
Hey oldschool,,, I just replace the sensor on the rearend today an it still don't work,,, But I did go to the dealer an ask them about it today also,, An they told me that the PCM box mite need to be programed before it will work,,, Heck no I not going to let them program my PCM box at all,,, So I guess I can try what you are telling me,, I will get my wife to call the place where I bought the new PCM an talk to them about it,, If they think it can be the PCM box then I am sure they will send me another one cause this one is life time,,,, Let me know what ya think now about it oldschool an Thanks,,,
