how much does 2000 durango engine replacement cost?
my friend selling nice durango for 1000 but needs engine replacement, he says its a bad engine and won't start. soo how much does it cost to replace engine?
depends where you get it at.... i have seen them as cheap as $900 and as expensive as $2000... How many miles are on the truck?? i would be willing to bet with help from a few on here the motor could be saved..
The engines in these trucks are known to be almost bullet proof.. so unless someone did some extreme abuse to this truck the internals of the engine should be good and its probably just something less expensive that needs fixed.... just my
Wow really? Is that mostly because the 5.2 and the 5.9 are more popular in the half ton trucks?
its bc the 5.2 and 5.9 have been around for a while so there are alot more of them around, also the 4.7 has gone through a couple of changes in its relatively short life so finding one that is a drop in fit can be more difficult.
