Help me PO725
Old Jun 28, 2012 | 02:59 PM
blackshirts's Avatar
blackshirts
New Member
Default Help me PO725
Help me PO725 code and no buss came on as well on 2002 durango was going to work and truck just died restarted dash went haywire then came back on died again limped home no guts doggy and the only way i can get it to start is gas in thottle body then runs for a bit then go back to it and it just cranks and cranks D i need a new fuel pump or what
Old Jun 28, 2012 | 03:23 PM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
from here https://dodgeforum.com/forum/1st-gen...ine-light.html
P0725-ENGINE SPEED SENSOR CIRCUIT
i hope you have the 4.7l v8 in your truck, it sounds to me like a crank position sensor to me, its on the passenger side of the block and is necessary for the PCM to get the timing correct.
