No headlights
Old Jul 18, 2012 | 12:05 AM
Maxed's Avatar
Maxed
Default No headlights
Fuses, Relays and a new headlight switch. Bulbs check out fine. During the day the blinkers, brake lights etc work fine. Once the switch is turned it kills the rest. Both the old one and the new one. Ideas?
Old Jul 18, 2012 | 01:06 AM
majerus's Avatar
majerus
bad switch -- EDIT* Did not see that you already bought a new one... Does it blow the fuse?
Old Jul 18, 2012 | 09:22 AM
that_guy's Avatar
that_guy
sounds like a problem with the wiring. If the fuse is being blown it could be a short, if it's not it might just be a bad ground.
Old Jul 18, 2012 | 05:00 PM
Maxed's Avatar
Maxed
Its not blowing any fuses and I've checked grounds and all bulb sockets. I've also used silicone grease in all sockets to make certain that no moisture or dirt can get in. This one has me stumped.
Old Jul 18, 2012 | 08:06 PM
that_guy's Avatar
that_guy
may be the ctm going bad then
Old Jul 18, 2012 | 10:44 PM
Maxed's Avatar
Maxed
Update! Faulty new light switch. Drove two hrs this evening with headlights on and no issues! Took it back to Napa on the recommendation of the manager and he said it wasn't the first time something was defective. Wife is happy which means I'm happy!
Old Jul 19, 2012 | 09:28 AM
that_guy's Avatar
that_guy
that's good news because chasing down wiring problems is a pain in the ****, and the ctm is expensive.
