2002 Dodge Durango 4.7L NO BUS
Old Jul 30, 2012 | 01:01 PM
robomow's Avatar
robomow
For those searching for this problem. In my case it was the Power Control Module (PCM). Or the dodge engine control computer. Mine is mounted beside the air box housing on the passenger side inner fender. I'm rolling now. I wish to thank all those who took the time to reply. Thank you very much!
Old Aug 16, 2012 | 03:01 PM
lezlee's Avatar
lezlee
New Member
Soooo...what was wrong with this truck after all ???? 'Cuz now i'm having this problem : (
Old Feb 22, 2015 | 11:04 AM
Ritchie's Avatar
Ritchie
Default no bus and p done error
My Durango was driving down the road it would shut down turn the key off and start right back up I change throttle positioning sensor crank sensor MAP sensor and spark plugs now it just dies when its in park or idles down and Die then start right back up and drives but not sure how to fix it maybe fuel filter I have 50psi on gas pump ? I'm going to be n det if I keep trying to fix it one thing at a time kills your money .
Old Aug 2, 2015 | 05:28 PM
Marti Hawkins's Avatar
Marti Hawkins
the computer needs to be replaced mine did this to and that is how i fixed it
