finished the last of the problems with the 99
Old Jul 28, 2012 | 03:35 AM
moparman_2004's Avatar
moparman_2004
Default finished the last of the problems with the 99
last october i bought a 99 slt and bought it with a cracked radiator they payed for the radiator i put it in no problems till the other day wife got home and just started pissing antifreeze down the driveway so the radiator had a lifetime warrenty so i went and got a new one and got it in in just under 3 hours started looking at the bad one and the orings failed around the tranny lines into the radiator
then problem to the rear wiper motor never worked right it would only wipe if it was on and pushed in for spray and once you let up off the spray and the wiper stops were its at so i replaced the switch didnt fix it went to the wrecking yard ordered a 99 rear wiper motor and it was diffrent then what was on there and the plug was diffrent so i went back to wrecking yard again and looked at one for a 01+ and it was the same so at some point the po replaced the 98-00 hatch with a 01-03 so i went back and returned the motor and bought the wiring out of a 98-00 hatch and rewired the hatch got it all back together and finally works like it should
