Need some advice
Old Aug 1, 2012 | 08:45 PM
Michael Edward Arnold's Avatar
Default Need some advice
2003 Dodge Durango SLT 4.7 4x4
at present: 265/70R16
Can i go with a 275/70R16?
Is the only difference the width of the tire?
Any help you can give is appreciated.
Old Aug 1, 2012 | 11:32 PM
dsolorio's Avatar
dsolorio
Width / Height "R" Rim Size
Yes, its only a wider tire.
Old Aug 2, 2012 | 03:12 AM
DyingBreed's Avatar
DyingBreed
I thought that the second number was the aspect ratio so therefore it would be slightly taller as well?
Old Aug 2, 2012 | 09:22 AM
Thanks,
I just wanted to make sure before I ordered these tires. I am pretty sure they will fit. Guess we will find out.
Old Aug 2, 2012 | 11:25 AM
DyingBreed's Avatar
DyingBreed
it should fit no problem. on a rough estimation and due to slight manufacturer differences yours sizes for total diameter roughly equal : 265/70 = 30.6" and 275/70 = 31.15"
most tire websites have tire calculaters or usually the tire brand list the specifics in tire sizes and etc for info on a specific tire.
Old Aug 2, 2012 | 05:16 PM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
it should fit, however it WILL be slightly taller than the stock tires as the second number is a ratio of height and width
Old Aug 2, 2012 | 08:11 PM
dsolorio's Avatar
dsolorio
Yes this is true. Its the ratio of the first number, but considering the width is only 10mm more, it wouldn't be very much.
