98' 5.2 Expansion Valve Location
Old Aug 4, 2012 | 10:29 AM
Supertwins's Avatar
Supertwins
Default 98' 5.2 Expansion Valve Location
Anyone know where the expansion valve is located on the 1998 Durango front AC? I would like to replace myself if the dash does not have to be removed.
Old Aug 5, 2012 | 12:48 AM
Compactc9's Avatar
Compactc9
THe expansion valves are usually on the evaporator, so you probably do have to take the dash out to do it.
Old Aug 5, 2012 | 03:22 PM
adukart's Avatar
adukart
It is in the engine compartment located on the firewall behind the intake box. All the A/C lines go into it, it is easy to spot but you need some A/C line separator tools. I found them at Oriellys for like $6. Why do you want to replace it anyways?
