ABS and Brake Indicators on After Replacing PCM
Old Aug 6, 2012 | 10:29 PM
dakotamagic's Avatar
dakotamagic
Default ABS and Brake Indicators on After Replacing PCM
My PCM was indeed the problem for the no bus thing. Now that that issue has been taken care of, my ABS and Brake indicator lights came on. I was out playing around and my anti-lock brakes DO NOT work. Is there a fix for this. Any ideas what's causing it?
Old Aug 6, 2012 | 11:13 PM
Old_School's Avatar
Old_School
You did have the dealer program you PCM with your VIN # BEFORE you stuck it in right?
Old Aug 6, 2012 | 11:26 PM
dakotamagic
Good question... I have no idea. I didn't put it in so I don't know.
Old Aug 7, 2012 | 05:21 PM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
that is the most likely cause is that the correct VIN wasnt programmed
Old Aug 7, 2012 | 06:36 PM
dakotamagic
So can I take the part out when I get home and have the dealership program it?
Old Aug 7, 2012 | 08:09 PM
shrpshtr325
THE ULTI-MOD
yes, however you cannot drive the truck without the PCM in it, and it may not be cheap
Old Aug 7, 2012 | 08:25 PM
dakotamagic
Ok. At home I have another car I can drive while PCM is programmed. And are car parts/upkeep ever cheap? Hahaha.
Thank you for your help! :-)
