RobertM 98 Durango
Old Aug 17, 2012 | 03:44 PM
RobertM's Avatar
RobertM
Unhappy RobertM 98 Durango
We have a 98 durango slt with the 5.9 magnum. It all started one day when the wfe came home from work. It had a miss, I replaced plugs, wires, cap and rotor, still has the miss.
We took it to the garage, mechanic replaced all sensors, distributer, plenum gasket. Since then the idle has gotten worse, will not stay running. I even replaced both timing gears and chain thinking that may help. NOT..... I'm ready to blow the D*# Durango into little peices.
Help Please?????
Old Aug 17, 2012 | 06:17 PM
Old_School's Avatar
Old_School
Help Please?????
Sounds like a similar issue that another member had... the fix was a new PCM...
Here is the thread-->https://dodgeforum.com/forum/1st-gen...-lifetime.html
Old Aug 18, 2012 | 09:41 AM
RobertM's Avatar
RobertM
Thanks old school, I've tried everything else, I'll try that next.... I'll keep ya posted on the progress.
Old Aug 19, 2012 | 04:27 PM
hydrashocker's Avatar
hydrashocker
Also I would replace the coil seeing how you've done everything anyway, and re-route the wires to the TSP requirements.
Any codes?
