Rear Passenger Window trouble
Old Aug 28, 2012 | 04:31 PM
BrandonKnight17's Avatar
BrandonKnight17
New Member
Default Rear Passenger Window trouble
I have a 1999 Dodge Durango SLT. The suv was running great until the passenger rear window didn't move up or down.You could push it down with one finger down with no problem. The switch is okay, I heard a snap like a wire and now the window motor is trying to go up but doesn't seem to be pushing the window. The window is currently being held up by duct tape.Could someone tell me what could have happen or give me schematics to the inside of the passenger rear door/window.
Old Aug 29, 2012 | 08:40 PM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
https://dodgeforum.com/forum/dodge-d...s-section.html
Old Aug 29, 2012 | 08:47 PM
BrandonKnight17
New Member
Default Rear Passengar Window trouble
I have a 1999 DodgeDurango SLT V8. The suv was running great until the passenger rear window didn't move up or down.You could push it down with one finger down with no problem. The switch is okay, I heard a snap like a wire and now the window motor is trying to go up but doesn't seem to be pushing the window. The window is currently being held up by duct tape.Could someone tell me what could have happen or give me schematics to the inside of the passenger rear door/window.
Old Aug 29, 2012 | 09:05 PM
cummingetit's Avatar
cummingetit
I had the same problem. There is a plastic half moon shaped piece of plastic that the cable goes around. It broke off and the only way to get that piece is to buy a new regulator for 150 bucks. I used jb weld to fill the hole where it broke off, then drilled a hole and used a nut and bolt to hold it back in place. Hopefully yours is this "easy". (quotes because it was the biggest pain in the butt to get the cable back on)
Posted from Dodgeforum.com App for Android
Old Aug 29, 2012 | 09:36 PM
cummingetit
Also my drivers window popped out of the regulator some how during the winter. It was frozen shut and made a pop when I tried to open it, thought it was broke for a week then I hit a bump and it fell. I noticed it stopped about halfway so I pushed down and it made another pop and worked just fine ever since. I don't think this could be your problem but never know til you get the door panel off and take a peek
Old Aug 29, 2012 | 09:37 PM
jim1999's Avatar
jim1999
I have a used motor if you are interested.
