Question about lifts
Old Aug 30, 2005 | 09:51 PM
CaptKidd's Avatar
CaptKidd
Default Question about lifts
So the question is if you install the 3" body lift and the 5.5" suspension lift, can you then run 35s? Also has anyone installed a winch on the front of their Durango? If so which winch and which bunper did you use?
Old Sep 29, 2005 | 08:21 PM
t.lay's Avatar
t.lay
Default RE: Question about lifts
I've been looking into this - Winch bumpers are not easy to come by for the durango/dakota. I'm leaning toward the road armor bumper. For the lift - you may have some interference issues with 35"s with more to do with tire width. Most of what I have seen are 3" or 3 1/2 lifts with 33"s. I've seen a couple of rigs go big with solid front axle conversions.
Old Sep 30, 2005 | 04:59 PM
Dave in LB's Avatar
Dave in LB
For a winch/bumper mount check out this web site. Also to run 35's i don't think you will need to lift your truck 8.5". For instance you can do a 2" torsion bar/shackle lift for about $50 and a few hours of time. That alone will fit 33s. Also check to ouside tire diameter of the tires you intend to use. For instance a BFG OTD for the AT/ko is 32.7" in a 33x10.5x15 so you can see you don't need as much room as you think for the tires. Articulation may be abother matter. Add a body lift if you must for another couple of incehes and 35s is pretty doable. Don't forget that you will need to swap out your front and rear gears on a Durangofor those tires as the Diffs don't seem to be strong enough to deal with tires that big and heavy for a long period of time.
http://www.kenmtn.com/
