easy/not so messy oil change?
Old Oct 13, 2012 | 05:08 PM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
the plastic piece is a splash guard in place under the front of the engine on 01-03 trucks (not sure about 00)
Old Oct 13, 2012 | 06:33 PM
jjphurst's Avatar
jjphurst
The factory shroud comes down to meet the crossmember on mine, but there is a screw out plug about 5 inches in diameter to allow for access to oil filter. I use a piece of cardboard rounded and stuck below the filter to drain it away from everything.
Old Oct 14, 2012 | 08:21 AM
alwaysclean19's Avatar
alwaysclean19
Originally Posted by Old_School
The OP never stated the year or engine of his truck... just sayin
Just flexing my psychic muscles.
Originally Posted by Duralude09
hey guys here at forum im new. just bought a 2000 durango slt 4wd 4.7l. it has 232K on it and yes i know its alot but i know the owner and it been maintained though this summer she said it starts heating up when sitting still so i have it home now and im about to change the thermostat * dumb location btw*
anyways if this doesnt work do i look at the mechanical fan next or water pump?
Old Oct 14, 2012 | 09:12 AM
Gafn's Avatar
Gafn
Originally Posted by shrpshtr325
your the rare case having an oil leak mine doesnt leak at all, i put 6 qts in i get 5.5 out after 5k miles.
Well I bought this a month ago... it leaks like the top of a beer can....
It has developed a head gasket issue, it will not run properly at startup...
Good thing I only paid $1500 for it... the interior is really nice....
Time to look at a re-power for it as this engine has 218K on it
If I could fit in a SBC I would - maybe a perkins or a cummins Diesel - this 4.7l appears really delicate
The cooling system needing to be bled - this is the first engine I have ever had to do this on, and there is no way to make sure you have all the air out...
Need to find the engineer who designed this and make him bleed all the 4.7l that are having cooling issues for the REST OF HIS NATURAL LIFE...
Old Oct 14, 2012 | 01:07 PM
shrpshtr325
THE ULTI-MOD
like i said, you clearly got a severely neglected and abused engine, but based on most reports on the engine and how few bad ones there are compared to how many have been sold, it is a solid engine when treated with a minimal amount of care
Old Oct 15, 2012 | 08:38 AM
Duralude09's Avatar
Duralude09
Sorry guys I've been busy but yes like Mr. Psychic said. Its 2000 4.7 4wd durango. It may have 235k on her but there's not a leak ANYWHERE. Well except occasionally I hear something like water dripping on exhaust when I get home.
Anyways the place Im talking about is where the drain plug is and I'm pretty sure the piece below it is metal.
Old Oct 15, 2012 | 11:55 AM
alwaysclean19
Like shrps said, replacing the drain plug with a valve and using a hose to direct the flow will allow for a much neater draining process.
