Catalytic converter bad ???
P0123,,,, P0107 ,,,, P1296,,,, All happen at one time,, Member my D was parked for 6 years an the pipe was cut between the cad an muffler,,, Well I hooked on my 19ft car hauler trailer an pulled it about 10 miles an after I parked it for 3 to 4 hours then this is what happen,, My parts are good cause I replace em but didn't help me any,, So this is why I starting to feel the cad mite be going bad or is bad,,
P0107 Map Sensor Voltage Too Low
P1296 No 5V to MAP Sensor
Seems to me that it is a issue with the MAP sensor not getting the 5V it should. The P1296 is most likely causing the P0107 and once the first is corrected the second should cancel too. These codes AFAIK have NOTHING to do with the cat. If i where you i would leave it alone..
Sounds like what you first need to to is look for some blown fuses... if nothing is found that i would grab a multi meter and check for 5v in the feed wire (Cav 3, Violet/White wire) If the power is there then you have a faulty sensor... in not then you need to start tracing wires and see where it stops...
While your out there... i forgot to mention if you not getting 5V on the feed wire i told ya check to make sure your connections are tight and clean to the PCM also make sure your harness is clean... IIRC the 5V signal comes from the PCM.
Just ran the test with my meter an found out my Map Sensor is bad, Has elc going to it an good ground but the vac part of it is not working as I tested it,, So now I going to try an get a new or or was wondering if a man went to junk yard an get one just to try it,,, hhhhmmmmm
