Tranny Swap got me going hmm
Old Nov 17, 2012 | 09:00 PM
atyo04's Avatar
atyo04
Default Tranny Swap got me going hmm
Well I am new here but maybe some one can help. I own a 99 Dodge Durango 5.2L 44RE transmisssion. about 2 months ago replaced the Transmission with a low milage used transmission with a new torque converter input and output Seals. did all the band adjustments replaced all the solonoids and sensors on the Transmission and new filter. adjusted the throttle and shift linkage. whent to start it now it misses and stalls out only when put into gear. Re -blew out the Tranny cooler and replaced the Cooler lines. still the same so I did a full engine performance test checked cam and crank position sensor signal tested the TPS, MAP, IAT, coolant temp sensor, oil pressure sensor, checked the PCV valve vaccume test compression test leak down test ect... all came out good. the torque converter sounds like it is wobbling so pulled it back out checked the flexplate again to see if it was loose or cracked checked to see if the converter was seated properly. Does not throw any codes
Old Nov 18, 2012 | 12:48 AM
adukart's Avatar
adukart
PM user mastertech he is the tranny guru around here. Sounds like the tc is trying to lock up when you put it in gear.
Old Nov 18, 2012 | 10:31 AM
atyo04's Avatar
atyo04
thanks for the response
