i would NOT be jumping to that conclusion right away without more information, it is only one possibility with others including bad headgaskets or a bad plenum gasket (depending on the specific engine there may even be other causes that dont come to mind right now)
Yea thats true but just me I have not had any headgasets go bad with just the oil part,, Or haven't seen any,, I hope it would be just the headgaset an not the oil rings,,
Oh ok,, That would about mean the Oil Rings are bad on the pistons ,,,, If it runs ok for a few days then starts misfireing then they make a part that you can put on the end of your sparkplug like an adapter an it will keep the oil off alot longer,, But I hate to say it you will be needing to rebuild the motor but no saying how soon,,,,,,
Luckily( so far) it has been running fine again- my hope is that its NOT a head gasket but that its something else entirely and easy to fix- will keep you all posted from what i researched it seems like a HUGE pain in the A$$ to change head gasket, but will keep my fingers crossed- thanks again for all the input guys
