2003 to 2000 mirror swap
I want to add heated mirrors to my 2003 Durango. I like the looks of the larger 6x9 mirrors. So far in my searching I am finding those mirrors where used up to 2000. I would like to know if the wiring harness is the same or if I am going to have to make a mess of things?
all trucks w/ the tow package got 6x9 folded tow mirrors, just find a set from the 2nd half andt he plugs will definitely match up.
the older ones will mount up to the truck no problem, however i believe that there are differences in the wiring (check with old_school, i believe he has done the research on this topic)
All the truck from 98-03 used the same mirrors (mounting wise that is) the difference is the 98-00's used a 6-pin plug and the 01-03's used a 8 pin plug. Why IDK as all years used 5 wires.....go figure.
the good news is all trucks 99-03 (98's excluded) where pre-wired for the heated mirrors even if the truck did not have them. With that said you should be able to get a 01-03 set and plug them right in. They where wired into the rear defroster system.
to the OP you have to be careful ordering the 6x9 mirrors as they do make a non-heated version. You could use the 99-00 mirrors you would just have to switch plugs.
https://dodgeforum.com/forum/1st-gen...o-edition.html
shop around rockauto.com had the correct mirrors for $60 a piece.
Trending Topics
Thank you for the link. I need to call rockauto Monday morning. Some of the mirrors are listed has "complete " and some are not.
