Diagnosing the inside of a high-mileage motor from the outside?
Old Dec 2, 2012 | 07:37 PM
heekma's Avatar
heekma
Default Diagnosing the inside of a high-mileage motor from the outside?
Hello,
Folks I'll be honest. I can replace a water pump, radiator, thermostat, fan, clutch, hoses, alternator, oil pan gasket and oil pump, brakes, plugs, wires, cap and rotor, simple sensors like oil pressure, IAC, MAP....basically the simple stuff.
I know the basics of how motors work-especially pushrod motors like my 5.9. Rebuilding my old Honda CX 500 taught me a lot about pushrod engines.
Can the more knowledgeable members help out a fella like me-enough knowledge to be useful, but also just enough knowledge to be dangerous?
Checking the oil: milky oil can mean a bad head gasket allowing coolent to mix with oil?
Plugs:
Light grey is good, carbon fouled means rich mixture, white means lean, oil fouled can mean worn piston rings-or worse?
What else can a fella like me look at from the outside of a motor and deduce what's happening on the inside?
Thanks for any info,
Heekma
