Stuck in 4x4
Old Dec 10, 2012 | 08:58 PM
stunami's Avatar
stunami
Default Stuck in 4x4
my 2002 4.7 litre slt stuck in 4x4 any body know what to do ? I move the switch and here clicking frm the vaccum but it does not disengage
Old Dec 11, 2012 | 05:55 PM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
the 2002 t-case is electronically actuated, check the motor to see if its moving correctly, and that the plug is on nice and tight
Old Dec 15, 2012 | 11:38 AM
stunami's Avatar
stunami
Smile Not the 4x4
Ok the noise that sounded like it was stuck in 4x4 was actually the wheel bearing . New hub, drivers side half shaft ,rotor, brake pads , then we will see if the grinding noise goes away thanks for info on the transfer case all the electrics seem to be ok
