Still no heat!! HELP PLEASE!!!
Old Feb 8, 2013 | 08:34 PM
Kimberley99durango's Avatar
Kimberley99durango
Default Still no heat!! HELP PLEASE!!!
A few wks ago my 5.2 overheated. Think it may have been low on coolant. Filled radiator, it was blowing cold air from the vents. Replaced thermostat, still cold. Burped it, then had hot air for about 30 sec.. The hose from the radiator to block is compressing.. Vacuum somewhere. I don't get what it is doing or what is wrong. It hasn't overheated since. But it's hardly getting up to 195 for the thermostat open. I'm very lost....
Old Feb 8, 2013 | 09:45 PM
Russ50's Avatar
Russ50
When the motor has ben running for a few min's did you feel any of the hoses under the hood to see if any of them are warm or hot or cold,,,
Old Feb 9, 2013 | 04:38 AM
Kimberley99durango
Yes they do get warm. and when you open the radiator you can hear the air go in and the hose goes back to shape. I haven't flushed the heatercore yet.
Old Feb 9, 2013 | 08:23 AM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
hows the coolant level in the overflow reservoir? there is also the possiblity of a blockage in the overflow line going into the reservoir which could be causing an issue
Old Feb 10, 2013 | 03:41 PM
Kimberley99durango
It looks like the overflow tank has a leak.
