2WD 99 d front bump stops..pics
Old Feb 9, 2013 | 07:35 AM
sp360d's Avatar
sp360d
Default 2WD 99 d front bump stops..pics
There is no info on front bump stops on a 2wd d, (so thought id post). I need info from anyone. On 2wd d's, the bump stops are on the bottom(4wd's i believe are on top of the a arms). From the pics you can see how bad mine are/were before i pried them out. Energy suspension doesnt have any that are 1.125"in width and 2" tall..as you can see, it is a very slim area their next to the coil spring. Anyone dealt with a bump stop shaped like these...my idea was to cut that metal cup out and replace with es poly, but energy suspension does not have one that slim in a wedge shape with a mounting bolt. How much would the dodge stealers charge for these cheap foam oems.
Attachment 18634
