Tansfer case broke
Old Feb 20, 2013 | 10:33 AM
mcnejs's Avatar
mcnejs
Default Tansfer case broke
I have a 99 durango 5.2liter 4x4 auto transmission. I noticed about a week ago a grinding noise. I thought it was a wheel bearing assembly because it sounded similar to an earlier issue I had when it was the wheel bearing. My wife was driving to town on the interstate with some of her friends and said all of a sudden the grinding got real loud. Then she heard a very loud bang or pop. She immediately pulled over and saw fluid pouring out from underneith. I had it towed home and jacked it up. I noticed the outer metal case on the transfercase was completely broken and severed from the rest of the transfer case. The break was where it connect to the front driveline. I had noticed a few days before this when I put it in 4wheel drive I would hear a clattering. It only did this in 4wheel drive. Also the vehicle was not in 4wheel drive when the transfer case broke on the interstate. Does anyone know what could have caused this? I know I need to replace the transfer case but I do not want to put a new one in and have the same thing happen to it. Thanks for reading and any help.
Old Feb 21, 2013 | 09:01 AM
WillyStreetDruid's Avatar
WillyStreetDruid
I'm no expert on the matter. In fact I'm currently researching whining symptoms on my own 1996 Dodge Ram 1500 4x4. I read a couple of possible causes. 1. Snap rings failing. 2. Bad Ujoints. 3. Low fluid. However, if you had fluid all over the place, rule that one out.
