Lift Kits
Old Mar 11, 2013 | 09:16 AM
Dodger_rango's Avatar
Dodger_rango
Default Lift Kits
I have been searching for a suspension lift kit for my durango.
all have been able to find for the 2000 4wd is a body lift.
anyone know were i can pick a suspension lift up at? I am at 2 inch now because my shocks are out all the way.
Old Mar 11, 2013 | 05:49 PM
rangoman17's Avatar
rangoman17
Yes there are only 2 other suspension lift options you can go with for a 2000 durango. One is a easy 2 inch suspension lift. Since our durangos have an under leaf spring our suspension works the opposite from most trucks. All you have to do is go to autozone and get lowering shackles for a chevy! I know it sounds like the opposite but since our leaf springs are under the shackles cuase it to lift. I put it on mine durango and it made a pretty big differnce. You have to remove the current shackles and put in the new ones in the rear and for the front you have to crank the torsion bars whitch is located right behind your shid plate. Its an easy lift and only takes about 2 hours (max) with someone helping you. The second lift is a 5.5 inch whitch is super expensive and that gets into things that are way to complecated and really its not a reliable lift and I dont know much about it. But thats up to you. Hope this helps let me know if you habe any questions. Rangoman17
Old Mar 11, 2013 | 06:34 PM
rangoman17's Avatar
rangoman17
Here is a picture of mine. It has that 2 inch suspension plus 3 inch body on some 33s.
Old Mar 12, 2013 | 02:58 PM
Dodger_rango
Yeah i already have the torsion bars up for the 2inch's.
i geuss now time for a body lift then.
