diff dissasembly help please. for the love of god!!!
Old Apr 24, 2013 | 02:39 AM
krupaeric's Avatar
krupaeric
Default diff dissasembly help please. for the love of god!!!
I need to replace My rear axle bearings. And I need help with the dissasembly of the diff. I have the haynes manual but it doesnt give me good enough directions. So please please. Will someone please help me with the diff dissasembly. I can not Drive My d untill I Get the bearings replaced. And I need My d fixed asap. Please. Help.
Old Apr 24, 2013 | 04:17 AM
DyingBreed's Avatar
DyingBreed
Check the FSM?
Old Apr 24, 2013 | 08:31 AM
krupaeric's Avatar
krupaeric
Fsm? I just did a search on you tube and found a video of a guy WHO was replacing his axle seals. And I beleive I know how to do if now. Just un Bolt the rod that holds the c clips in place gently remove the rod. Remove the c clips. And shazam the axles can Get pulled out. I didnt know it was that Easy. I was told I need to disasemble the whole diff in order to Get the axles out. Bit I beleive I will tackle this job on the next nice day here.
Old Apr 24, 2013 | 09:04 AM
DyingBreed's Avatar
DyingBreed
Factory Service Manual. It puts the Haynes/Chilton's to shame. They're good for a quick reference, but the FSM is far more detailed and specific about things. Google it for your year durango and save it. Print what you need when you need.
Old Apr 24, 2013 | 09:54 AM
that_guy's Avatar
that_guy
You don't even have to google it. Go to the diy section that's stickied at the top of the first gen page and then the links to the fsm are 1 or 2 things up from the bottom.
Old May 10, 2013 | 03:48 AM
srch4me's Avatar
srch4me
yup its as easy as pulling the diff cover, removing the bolt that holds the rod in the center of the differential, remove the rod, and push on the axle and the clip can be removed if it didn't already fall off.
