2002 Durango sit low on driver side
Old May 21, 2013 | 09:04 PM
slate10257's Avatar
slate10257
Default 2002 Durango sit low on driver side
Can anyone give a little advice on a 2002 Dodge Durango? Its sits low on the driver side, almost an inch from passenger side. It is a RWD SXT model with 4.7L engine. I am pretty confident the shocks need replaced but is there anything else I should look at to make sure there is nothing else wrong.
Thanks for any help you can provide.
Old May 22, 2013 | 05:57 AM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
https://dodgeforum.com/forum/dodge-d...s-section.html
ill move this
Old May 23, 2013 | 05:54 PM
hydrashocker's Avatar
hydrashocker
Most likely a bad a bad spring.
Now are you talking the frint, rear, or both? Also could be body mounts.
