New sound system.
Old May 22, 2013 | 10:56 PM
Jdahlberg17's Avatar
Jdahlberg17
Default New sound system.
Hey everyone I just got an amp some subs and a new stereo. I was just wondering how do I install the amp and subs in my 1999 dodge Durango SLT? I know how to do the stereo but not so sure on the amp and subs? any help or instructions would be great!
Old May 23, 2013 | 12:14 PM
Dig-N-Deep's Avatar
Dig-N-Deep
Power cable goes to the battery and pull up the trim panels on the floor and run it under there and hook it to the amp. You also need to run your RCA cables from the deck under there with the remote wire from the deck and then you need to make a ground I use the bolt the holds the third row seat down I take it out put the ring terminal on it and bolt it back down scratch the paint some to get a good ground your amp should then power on when you turn your deck on
