Issues again
It's been awhile since I posted here on this but I just checked again and I am still able to turn the front shaft but I did not see any movement on the axles or cv area.
I have not driven her in a month and I am missing it badly. With the drive shaft like this is the shaft itself that needs replacing or something inside the case or differential?
And when I was driving her I didn't notice any difference in the sound with turns.
Just to double check something, months now down the road and it's looking like I may be able to replace the tcase. How do I know which one I have? I took a pic and it says 242 D. I do not know if it is the NV or the NP 242, how do I tell the difference?
Yep, atf+4 only in the transfer case and transmission.
As for the np vs nv I'm almost positive they should be interchangeable as long as they came off another Dodge 44/46re.
I am now down to two damn nuts on this thing and cant reach them to be able to get them off. Even with the hiccups it's a relatively easy process once you have everything.
Question when I removed the rear drive shaft there was fluid leakage from the back of the tcase. Is this normal and do I need to worry about it when I finally get the tcase removed and dropped from the transmission?
