knocking
Old Jul 10, 2013 | 07:49 PM
jason7300000's Avatar
jason7300000
Default knocking
I have a slight knocking buy my front drivers side tire I am thinking ball joint is bad any ideas?
Old Jul 11, 2013 | 08:13 AM
SmokinJoe02's Avatar
SmokinJoe02
could be the hub bearing
SJ02
Old Jul 11, 2013 | 10:13 AM
go-part's Avatar
go-part
Former Vendor
When do you hear the knocking noise? (slow turns, bumps)
Old Jul 11, 2013 | 04:38 PM
gnelson49's Avatar
gnelson49
Have you raised the vehicle and checked the camber in the wheel? Grab the top and bottom of the tire and push in/out on top and bottom, do you get a lot of movement? That would be indicative of bad ball joints and possibly tie rods as well. Also, rotate the tire while it is up in the air and see if you hear the same noise.
Old Jul 12, 2013 | 12:12 AM
jason7300000
I hear it during slow turns.
Old Jul 12, 2013 | 12:13 AM
jason7300000
Its not bad but I don't want it to get worse. Hoping it is an easy fix.
