Need help!!! Fan clutch nut is stuck
Old Aug 12, 2013 | 11:46 PM
Ksukat's Avatar
Ksukat
Default Need help!!! Fan clutch nut is stuck
Need to remove the fan and clutch on a 1999 Durango 5.9L engine so I can replace the water pump. It absolutely will not budge. We have tried every wrench possible, breaker bars, WD-40, rust ease, butane torch.... It's to the point now that the nut is starting to deform. What options do I have? Can I get the fan and water pump out altogether and just replace them all?
Old Aug 13, 2013 | 08:21 AM
Welcome to DF! Moving this to the Durango section so you can get help.
Old Aug 13, 2013 | 11:29 AM
rjlane1@pacbell.net's Avatar
rjlane1@pacbell.net
Duplicate
Old Aug 13, 2013 | 11:57 AM
clipper77's Avatar
clipper77
Are you sure the threads on the nut are not left handed?
I had a similar problem and it was because of reverse threaded bolts/nuts.
Old Aug 14, 2013 | 09:16 AM
Ksukat's Avatar
Ksukat
Finally got it. We ended up just putting a LOT more heat on it, way more than before and it finally broke.
Old Aug 14, 2013 | 09:23 PM
PublicHair's Avatar
PublicHair
Yeah, it's reversed and you just need to beast it. Don't put too much heat but sounds like you got it.
I just ditched it. But my truck came with a factory e-fan so I had no desire to replace the clutch.
Old Aug 15, 2013 | 12:19 AM
that_guy's Avatar
that_guy
Mine has normal threads.
