Fan clutch nut completely stuck - need help!!!
Old Aug 12, 2013 | 11:57 PM
Ksukat's Avatar
Ksukat
Default Fan clutch nut completely stuck - need help!!!
Need to remove the fan clutch nut on a 1999 Durango 5.9L engine so I can replace the water pump. It absolutely will not budge. We have tried every wrench possible, breaker bars, WD-40, rust ease, butane torch.... It's to the point now that the nut is starting to deform. What options do I have? Can I get the fan and water pump out altogether and just replace them all? I'm out of ideas.
Old Aug 13, 2013 | 01:15 AM
rjlane1@pacbell.net's Avatar
rjlane1@pacbell.net
I had a hell of a time getting mine off but finally had success using a chain strap wrench to hold the pulley in place while hammering a big crescent wrench (counter clockwise). A little pb blaster may have helped as well.
Old Aug 13, 2013 | 11:00 AM
rjlane1@pacbell.net
Probably stating the obvious, but the nut does not come off, so to speak. It is attached to the fan, so the nut and fan should all be turning.
