Gatorfan59
Old Aug 20, 2013 | 07:06 PM
Davidr5966's Avatar
Davidr5966
Angry Gatorfan59
I drive a 2001 Durango 4x4 and I have some problems that could use some help in resolving. My driver side low beam won't come on,(bulb replaced with no luck), the right turn signal blinks faster than the left, my engine light just came on and both of my remote keys stopped working (at the same time). Any ideas on what could be causing these issues. Thanks for any help!
Old Aug 20, 2013 | 09:07 PM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
https://dodgeforum.com/forum/dodge-d...s-section.html
ill move this for you to the first generation section
the right side turn signal is most likely a burnt out bulb, there are 3 bulbs in each of the front fixtures
get the codes read for the engine light (or do the keydance) and let us know what codes come up
as for the low beam, its probably a broken wire, you need to check continuity and figure out where the open in the circuit is.
and the remotes not working is possibly and issue with the CTM
Old Aug 21, 2013 | 06:25 PM
Davidr5966's Avatar
Davidr5966
Thanks for the help! I already checked the bulbs on the blinker and all are working. It is just weird that all this is happening at the same time. I wasnt sure if it was my CTM.
