cooloing system
Old Aug 25, 2013 | 09:39 AM
jimamoses's Avatar
jimamoses
Question cooling system
Hi to all. My 2000 Durango with a 5.9 makes a gurgling/boiling sound where the top hose goes into the radiator. This only happens when the engine is shut off after a normal drive. I have a Ram the same year and motor and haven't had this problem. Any ideas on the cause of this?
Thanks,
Jim
Old Aug 25, 2013 | 09:48 PM
moe7404's Avatar
moe7404
get the radiator checked for being clogged. and / or the stat. when putting the stat in DO drill a 1/8 hole the the plate. that will let the air go through and let the coolant fill better. beleave it or not that mod is approved by chrysler. its a long story, but very interesting.
Old Sep 1, 2013 | 08:11 AM
jimamoses's Avatar
jimamoses
Thermostat did the trick thank God! Thanks for your help.
jim
