do i need to swap anything from 2000 4.7 to a 2001 dur ango 4.7
Old Sep 11, 2013 | 07:38 PM
tristen23's Avatar
tristen23
Default do i need to swap anything from 2000 4.7 to a 2001 dur ango 4.7
I have. A 01 durango 4.7 which needs a motor ..i have a parts durango which is a 2000 durango 4.7 that im going to put the motor in my 01.do i need to swap anything from motor to motor some ppl say i need. To swap tone wheel an flywheel? Is this true
Old Sep 12, 2013 | 02:00 PM
RockGuardedDak's Avatar
RockGuardedDak
To an extent. Is the 01 a 3 or 4 plug computer? Same question goes for the 2000, 3 or 4 plug computer? 3 plug style motors can be swapped with 3 plug motors, as can 4 plug to 4 plug, but if you want to swap a 3 plug motor to a 4 plug motor, or vice versa, modification to the motor will need to be done to get it to work.
Old Sep 13, 2013 | 07:50 AM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
you should be fine, as stated aboce the PCM plug count needs to match, but they didnt start putting 4 plug units into the durango until 02 so both of yours should be 3 plug
