Front hub assembly without antilock sensor?
Old Oct 5, 2005 | 11:21 PM
Dylan's Avatar
Dylan
Default Front hub assembly without antilock sensor?
I just finished replacing the front passenger side wheel bearing assembly on my 99 Durango and i've got a question. I bought one at Autozone, got it home and pulled it out of the box and it had the antilock cable attached to it. My old one didn't have it, so I returned it and got another one from C.A.P and found it also had the antilock cable. After a conversation with the guy from cap he double checked the numbers for my year truck and it was the right one. He said my truck should have 4 wheel antilock brakes but i don't have any cables coming off my from wheel hubs. Everything else is identical except the cable, so i just cut the cable off and installed the assembly. Did they make a 99 Durango with 2 wheel antilock brakes?
Old Nov 11, 2005 | 05:08 PM
lamrouex2004's Avatar
lamrouex2004
Default RE: Front hub assembly without antilock sensor?
My 99 durango only has rear anti-lock. And I just replaced the front hubs, Napa had one with the sensor and one without, you can cut the sensor cable off or zip tie it out of the way if you can't purchase a hub assembly without one.
