2002 4x4 Front Rotor Removal
Old Oct 10, 2005 | 06:04 PM
daveinhb's Avatar
daveinhb
Default 2002 4x4 Front Rotor Removal
So I changed the discs, but the rotors are rough and need turning. If I can get them off myself I can get done for a fraction of the $135 the local shos charge to remove the rotors and turn. Being a 4x4, how difficult is this? The rear drums come right off.
Thanks in advance, you guys rock.
Old Oct 13, 2005 | 11:26 AM
jciscott's Avatar
jciscott
Default RE: 2002 4x4 Front Rotor Removal
Dude.... Removal is simple... just pull off caliper, and tap on the rotor to break the rust-seal.
I would NOT EVEN THINK OF TURNING DURANGO ROTORS !!!!!! OEM replacements are only about $40 at Advance Auto Parts and I got real snazzy cross drilled, vented rotors, new on eBay, for $100 with Shipping.
Rotors are cheap, cheaper than turning. Get new ones....
Old Oct 13, 2005 | 11:30 AM
DevilsReject's Avatar
DevilsReject
Noob Assassin
jciscott is absolutely correct. It is not WORTH turning the OEM rotors on a Durango/Dakota. The rotors are made of much softer/crappier material then they need, and often wear out relatively fast. You are better off spending $90-150 and replacing them with better aftermarket parts. Trust me, you will notice a big difference. The stopping ability not to mention less brake dust all over your front wheels will show up quickly.
Honestly, I'd be surprised if any shop was even willing to turn your rotors as I've had 2 Dakotas and no shop would even so much as touch my OEM rotors....
Good luck on whatever you decide!
Old Oct 15, 2005 | 04:49 PM
hydrashocker's Avatar
hydrashocker
[sm=funnypostabove.gif]jciscott
If you can't take off a rotor, and you can't buy a REPAIR MANUAL, don't attempt to work on your vehicle![sm=partyparty.gif]
