03 durango error code help
I have a 03 durango just got it back from the shop had lifters putt in it had spit 2 rocker arms and it still rattles at startup and I got a few engine codes they are
P0352 p0354 p0356 p0358
P0507
P0113
P0340
Also the lifters replaced were on 2 4 6 8 cylinders any ideas as to whats goin on
It starts and runs no missing or anything noticeable but does have a high idel at around 1000 to 1200 rpm
An help would be appreciated thanks in advance
P0507
P0113
P0340
Have you looked at this thread? https://dodgeforum.com/forum/1st-gen...ine-light.html
P0352 Ignition Coil # 2 Primary Circ
P0354 Ignition Coil # 4 Primary Circ
P0356 Ignition Coil # 6 Primary Circ
P0358 Ignition Coil # 8 Primary Circ
P0507 Idle Ctrl Sys Hi RPM
P0113 Intake Air Temp Sens Voltage Hi
P0340 No Cam Signal At PCM
I am no mechanic, but it looks like something might not be connected correctly when they put the "electrical" back together.
