2003 Doge Durango rpms up and down
Old Mar 4, 2014 | 02:39 PM
rgamez815's Avatar
rgamez815
Default 2003 Doge Durango rpms up and down
Having problems with rpm's up and down and speed not incresing Help.
Old Mar 5, 2014 | 10:51 AM
hydrashocker's Avatar
hydrashocker
Try replacing the TPS sensor and remove and thoroughly clean the throttle body.
Old Mar 11, 2014 | 03:02 PM
thebenman28's Avatar
thebenman28
Hi, I have an 01 durango with the 4.7 that was giving me issues like that all of a sudden. Especially on cold starts. The engine would rev itself up to 1200 rpms then drop down to normal...and back and forth until engine got a bit warmed up. Then it was better but still idled a bit weird at stop signs, etc. Tested both the IAC and TPS. Got a good solid readong off the IAC, but the TPS seemed iffy. So I spent 35 bucks on a TPS, Swapped it out in less than 10 minites, and it runs awesome now. Starts and idles where it's supposed to, adjusts perfectly when I turn things on and off, seems to have solved the problem.
Old Mar 12, 2014 | 11:37 AM
rgamez815's Avatar
rgamez815
I replace the TPS and It is working just fine Thanks guys for the Help !
Old Mar 12, 2014 | 05:33 PM
hydrashocker
Your welcome guys.
