Extremely loud popping noise from under 1998 Durango
Old Mar 16, 2014 | 02:58 PM
bamabuc77's Avatar
bamabuc77
Originally Posted by pkucan
That is exactly how mine behaved. I replaced everything else before finding the problem. I should have had it up on blocks, running before I threw parts at it!
Cool. I'll put it up on jack stands tomorrow morning. Hopefully this is the problem. Thanks for all of yall's help!
Old Mar 16, 2014 | 05:22 PM
PublicHair's Avatar
PublicHair
Originally Posted by dxloat
Yup, ball joints has my vote considering they are arguably the weakest link in the front end of our D's.
Argue?
I think everyone just flat out agrees..
Old Mar 17, 2014 | 12:13 PM
hydrashocker's Avatar
hydrashocker
You can remove the front driveshaft to see if the driveshaft is bad, or diagnose further. It could be something in the front differential, driveshaft, rear differential, wheel bearings, ball joints, or control arms.
I once had that problem and it was the control arm bushing nuts worked loose. Found it when we put it in the air and shook it down.
