durango
Old Mar 15, 2014 | 11:26 PM
babyboy_6669's Avatar
babyboy_6669
Default durango
I have a 2000 dodge Durango im not getting fuel to the drivers side already put to much money in to it and need a little help........... do the fuel injectors run off a fuse or something else I have gas to the passenger side but none to the drivers side and the fuse box has no juice to the one fuse and I don't know y.... any ideas would be greatful thank you
Old Mar 16, 2014 | 12:19 AM
that_guy's Avatar
that_guy
I'd guess either a fuse or relay somewhere. I'd guess they'd be in the fuse box under the hood, but there are also fuses inside the driver's door on the side of the dash, and up under the dash on the backside of that dash fuse box.
Old Mar 16, 2014 | 09:41 AM
JeeperDon's Avatar
JeeperDon
Your statement is vague. You are not actually getting fuel to the left rail? ...or there is fuel and pressure there but the injectors are not firing to allow the fuel to proceed?
Old Mar 17, 2014 | 12:06 PM
hydrashocker's Avatar
hydrashocker
Heres an idea; I've seen rust get inside the fuel rail and plug it up. You have to remove the rail and blow it out then clean it up and the injectors.
