crank no start
Old Mar 22, 2014 | 07:45 PM
cahodson70's Avatar
cahodson70
Default crank no start
I have a 98 Durango 5.2 cranks fine but I have no power to ignition coil or fuel pump and gages are not working, inst. lights are working but no gages, I changed shutdown and fuel pump relays but no change. I checked all grounds and connections I'm stumped any help would be appreciated.
Old Mar 23, 2014 | 12:29 AM
that_guy's Avatar
that_guy
Sounds like the pcm to me. Try reseating the connectors to the pcm.
Old Mar 25, 2014 | 10:42 PM
Thax's Avatar
Thax
Possibly the Crankshaft position sensor. Vehicle will crank but will not start without a solid signal to the ECM from this sensor.
Old Mar 26, 2014 | 01:20 AM
that_guy's Avatar
that_guy
The fuel pump would probably still run if it were just the crank sensor though.
Old Mar 26, 2014 | 07:25 PM
Thax's Avatar
Thax
true it would still run , didnt see that detail. Possible PCM failure or possibly bad ground somewhere.
Old Apr 1, 2014 | 04:36 PM
hydrashocker's Avatar
hydrashocker
Could be something in the ignition switch as well.
